Stereo head unit
lewyy
I'm looking for all the specifications for the standard stereo head unit that is in. Device ID: 13TXDAEU-DA05. I can't seem to find it online and I don't know how to remove it from the car as well. I've removed the trim found 2 screws but I don't know how it comes out once I've removed the screws and don't want to brake it. It seems very hard to pull out if there is nothing else holding it in.
What specs do you need, it's between 7-9w rms per channel as its an oem product specification aren't in the public domain
Random vid off YouTube
I looked at ToyoDIY and it look like you pull the whole front surround facia with the audio unit. It is best to use plastic trim tools, so not to damage and scratch anything. Everything is held together by strong clips to reduce vibration and creaking. That's why needs a bit of force to dismantle.
I took mine off the top vents come off and can pull out vent and the head unit cover all in one .tbh feels like real cheap plastic and is easy scratched also with that shiny silver stuff.i don't like it at all plus need to take it easy as if gets loose the creaking will drive you crazy .my dash was creaking around bottom headunit housing and ash tray part I had to take mine out again and put a strip of that speaker foam in there to hold it better .tbh really bad design Toyota with those stupid clips. Rather have wee bolts holding those dash parts together
