Hi my car has been in for its m.o.t when I got it back after passing. I go out for a drive and the car starts to beep. I pull over and lift the hand brake up and down then it stops. Then I go on with my journey. And it can start again. then I repeat the same process. Anyone know what it could be please
Manual or X-shift?
anything on the passenger seat, is the seat belt where it should be any lights on the dash (red one stays on maybe)
2 hours ago, FROSTYBALLS said:
Manual or X-shift?
manual
no light on the dashboard above steering wheel. there's a yellow circle with a seatbelt in the middle where it shows seatbelts. will try to attach picture later.
Have the rear belts been left fastened ? (they do this when testing/checking the rear belts)
