2007 Auris rusty metal tube at rear?
jazzyman
Checking underneath my 2007 Auris today, there is a metal tube that is very rusty. What is it?
Hi, I believe it’s called a cross bar member or something similar. It adds a structural rigidity to the chassis. This is only a surface rust and nothing to worry about. Although if you prefer you can apply some rust converter and then paint it with black paint. This is what I had done to mine including rear suspension beam. They look much better then after .
image.thumb.jpeg.656d9f5ba6c5595c661f59abe602bf86.jpegimage.thumb.jpeg.7179a89f9d760674884106bbfe378814.jpegimage.thumb.jpeg.c0aac2b2158133efd5bba67160c1b2d4.jpeg
Yes, use any rust converter, either phosphate acid or tannin base. 4 hours later, you can spray it with spray paint that contains primer. Lidl usually sold them and they stick to everything for £3
How did you paint this? Just on the axle stands? Does the spray can work on that angle?
Yes on the stands. I applied rust converter and painted next day with black paint spray. Looks much better than before, it’s like an anchor of an old ship that been restored 😂👌
  • Haha 1
