Where to grab +12V feed for air horn?
mikmikmikmik
Many posts on  installing these, but I can't find anyone who says where I get the +12V feed to power these via the contacts from the relay.
Thanks.
Edited by mikmikmikmik
Spelling
If your car is non-hybrid you can pull it straight from the Battery
If it was me, I'd save myself the trouble and just get the horns from Lexus. They are proper two tone 'snail' horns that don't draw much current.
  • Like 3
On 5/3/2023 at 9:18 AM, APS said:
If your car is non-hybrid you can pull it straight from the battery.
Any info about the part number or who manufactures them? Thanks.
86520-75010 HORN ASSY, LOW PITCHED
86510-75010 HORN ASSY, HIGH PITCHED
Genuine Toyota
  • 4 months later...
Genuine Toyota
Thanks. How much have you paid?
I have not bought them. Lexus charges £44 each, which is a bit steep. You could get Toyota compatible aftermarket or second hand OEM.
Plug should fit as Toyota use the same single wire connector across most models.
If you currently only have one horn you may need to get a splitter.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
