As above - id like to plug the car into the laptop.....other half says its a little sluggish and has to gas it a bit more than usual.....if i plug it in it might give me a bit more info....my only initial thought is when i was putting the new plugs in a few weeks back i was very hesitant in over tightening them...so might not have done them up enough so a simple thing to check...off the top of anyones heads do they know the torque setting for them ?
Cheers.
Cheers.
This says 20nm.. https://club.autodoc.co.uk/pdf-manuals/club/toyota/iq-aj10/spark-plug/pdf/EN-how-to-change-spark-plugs-on-toyota-iq-aj10-replacement-guide.pdf
Cool - thanks.....i can at least check on that while i find out which software to use for the ODB stuff - cheers. Thanks very much.
Techstream clone with a mini VCI is your best bet
Righty perfect - thanks very much.
Oh = revisited the plugs last night....yeah i wasnt tight enough....i reckon about a full turn for each of them to get them up to spec.....went out afterwards - felt a little more responsive....probably loosing a bit of compression..!
