Brake master cylinder
TJF
Hi can anyone help with where i would be able to get a new brake master cylinder for my Toyota Celica gen 7 part number 47207-20151 can't seem to find one Toyota said they don't do them there discontinued any suggestions. ? Ter
It is also sold as part no 47207-20131
Both are available to order from Amayama. This does not mean they are still in production, but you could try a different dealer, search the interwebs or bite the bullet and order from Japan.
47207-20151
47207-20131
20151 is for cars with VSC (190 2zzfe, T231) you need the correct one
On 5/4/2023 at 12:50 PM, TJF said:
...part number 47207-20151...
That might not be the correct part number.
47207-20141 (without ESP) is showing on the parts catalogue I use.
Can you post your VIN number then I'll check again.
