Anybody converted their T27 2010 Avensis fog lights to DTRL?
ToNo10
Has anybody  converted their T27 2010 Avensis fog lights to DTRL?
If so please leave instructions and comments.
thank you 👍
thank you 👍
not sure it would past mot boss
The fog lights can not be used as drl. But they can be replaced with led drl lights. And the drl control system will be needed too..
Thanks for the replies, any link to replacement LEDS., please.
Must cost a fortune as I have a loose connection or something on my 2014 one not sure if it's a fault with the bulb as it looks ok but don't work 😞 and those Philips replaced ones are nearly 20 quid each . I'm going to take it out put on spade connectors and make sure all touching great and see if fault with the pins on main plug going into the fog light. The volt using my wee meter is less than 12v though like 11.30v r something like that but the other light is working ok. I just don't fancy paying 20 quid for a bulb that I don't need. Plus my last car VW group car I never in my time having the. Car change the fog light bulb and I had that car 11 years
wow thats nice +++
If anybody has bought and fitted the AliExpress replacement fog lights on a T27,  please let us know what you think of them.  Assuming that you actually received them from AliExpress 🙄
can i buy your fog light bulbs off you :) are they philips ones
On 5/7/2023 at 11:16 AM, ToNo10 said:
tbh i cant see anything ncheap from aliexpress been of any half descent quality just a bother for later on im guessing .shane got lights for inside his car and gave nothing but bother
I need my off light bulbs for the time being, I haven’t got replacement yet.
I have seen the same units that were much dearer. They probably all come from AliExpress 😤
