Toyota Yaris 2007 auto MM Transmission fault
James garner
Hi guys-
2007 Yaris auto
1. loss of power in gear one or low gears engine revs but car does not move
2. Thud sound when shifting gears
Any advice?
Scan the car for codes, see if it has snapped a drive shaft or busted a CV joint, But more than likely it's clutch/pressure plate or clutch actuator issue
Hi Thank you- I have been away and now received this response.
Its the MM semi automatic Yaris.
Thud sounds when gears shift?
On start from 1st - 2 and some times even 3rd gear- engine revs car will not move or engage in gear  with loss of power?
  • 4 months later...
Hi- whilst i am waiting for a Toyota appointment  for diagnostic  my Yaris suddenly lost power driving very slow with struggle at 20-25 miles with check engine light on.  Please can you advise- could this also be related to the actuator? This has happened a couple to tines and then an hour or so later the engine light turns off the the car power comes back  along with the above problems>
thanks would you be able to suggest a decent scanner?
