Car not starting getting only single spark
Kingerz
You said should you get a continuous spark, not a repeating one 🙄
19 hours ago, flash22 said:
yes it should go out
you can do a manual flash test for diagnostics by linking the 2 pins shown and turn the car on and count the flashes
have you done anything to the fob recently, like changing the battery, or has the fob fallen apart ?, pop the key apart and make sure the chip is still in the key
Only got single key with no buttons on keys never been apart, I can try that flash test and see what I get I suppose
My bad I tried explaining like something was cutting the spark out
What am I looking out for on the flash test, I’ve tried finding fault codes again nothings coming up
It will flash out the codes - you count the flashes.
Flashes from the cluster or where else? Should I take a video of the cluster then?
The EML will flash out a 2 digit code
Any way to get around the immobiliser?
No, the only option is to program a key - a decent locksmith will be able to read the chip in the key if it hasn't failed if it reads ok, it may be the receiver loop around the barrel
