Find replacements for 89661-52BC01
M.Hazber
Hi
My engine control breakdown, and I did not find the same part code in my city, is there any method to know what are the replacment part codes
It's rarely an ecu fault what codes do you have, what are the symptoms ?
89661-52BC01 is incorrect, Try 89661-52C01
that makes the car a GCC/UAE, Asia built car, NCP92 Automatic with a 1.3 (2NZFE) known in other markets as a Vios
Thanks for your response
Yes you are right i make mistake its 89661-52C01
The water enter to the ECU board and the car stop working
find a breakers/scrapyard and see what you can find
what is your location ?
Moved to the Yaris forum.
