Auris hybrid mk2 rear brake caliper and and mounting bracket
demballe2244
anybody know what the torque settings for Auris hybrid mk2 2015 rear brake caliper and and mounting bracket.
Bracket bolts 56Nm
Slider pins 35Nm
+/- 3-5 Nm not big deal. If you are using the correct size tools you can’t get them wrong even without a torque wrench.
Good luck
4 hours ago, demballe2244 said:
Fkin Tight.
Use regular socket wrench without extension. about 25cm or shorter and we never overtight them.  To open stubborn bolt, you can knock the wrench or hammer it with your bare hand. It should be opened without any issues.  Tapping movement for breaking loose any bolts or nuts are saver and easier.  I also avoid a lot of hand injury using this technique.  It is like how impact wrench works.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
