Solar Panel led modes against current in uA.
Derek.w
Led off current drain is 0.4uA  Battery supplying a small current.
Led on current drain is 0.2uA voltage 12.48 volts, photo cells producing electric but not charging. (voltage lower than the battery)
Led flashing 13mA up to 64.2mA voltage goes upto 12.69 volts (Battery charging)
After this photo cells stop charging Led flasing at a diffrent speed longer on delay until Battery voltage drops and it starts charging once again.
Some solar panels only have two states for led indicators on and off.
Sorry no info on mfg as this is a old solar panel and the stickers have gone adrift.
I decided not to bother with solar panels and cables. Will do ready mode once every two weeks or will try my £12.99 Aldi charger 😉
On 5/19/2023 at 11:22 PM, Derek.w said:
...Sorry no info on mfg as this is a old solar panel and the stickers have gone adrift....
Your solar charger has EAN 8591686071689
Compass 07168 Solar Charger
