Rav4 diesel fuel leak - engine bay mk3 2.2 d4d
CPK123
Need some advice, i have a slight diesel leak coming from below the area of fuel pump and fuel filter
Visually from above all is dry and clear, but it must be from somewhere below, I had the undertray off and there was a film but no major leak
The fuel is clean so I'm pressuming a return line as no codes for the fuel leak based on pressure drop at injectors
Any ideas on where to look?
