   When I try to shut my front window it goes up but hits the frame, seems to be a little plastic guide missing, anybody know the name/part number for it?
Many thanks.
It uses a centre lift regulator that is cable driven the window path is dictated by the lift and window runners these are built to a price (PSA part)
the rubber may have gone sticky with the change in temperature, lube it up with white grease or silicon spray (you can use furniture polish at a push)
RH - 69810-0H020
LH - 69820-0H020
I can't see any reference to any plastic guides, can you take a pic ?
