Denso parking sensor
amazighman
Hi
I have a Yaris verso 2003 fitted with Denso rear parking sensors , unfortunately these don't work and beep all the time.
Parking sensor is 188200-3581 , am unable to locate  any , anyone knows an alternative part number , sadly can't fit after market ones coz bumper holes are 25mm
That is a common Toyota part, so i would think it's a factory/dealer fit option back then
11/2002 is the change over date, there are 2 kits old style and new style the old type is 2 sensors the newer one is 4 sensors
looking at the Denso part number, it's the early type
https://www.toyota-tech.eu/aimuploads/{47414C82-642C-4336-8021-67FFFBA07D7E}/eaumc15.pdf
The Part has been discontinued
Thanks for that
I guess it Will be hard to find new ones.
Managed to find new aftermarket ones from China. They look very similar with same plug , however they are different part number.
https://www.ebay.co.uk/itm/254950441781?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JHfLV_osQ5O&sssrc=2349624&ssuid=obfnkgk9R0G&var=&widget_ver=artemis&media=COPY
Would these work?
It looks correct, PZ362-00208- is the Toyota part number whereas 188200-3581 is the Denso part number (Denso are the OE supplier)
Ok. Thanks Flash. i might order some.
Regards
Before you order any, have you tried the old WD40 repair?
Unfortunately two of the sensors are in poor state all cracked and water got in
I saw a video on replacing the sensors, it seems that unplugging any non-working ones may bring the unit back to a working state. Remember that the unplugged sensors will cause gaps in the units coverage, so be extra careful using it for guidance in that condition. Also, that was on an aftermarket parking unit, so it may not be the same for the factory fitted one. It may at least help to stop the constant beep when in reverse gear.
Thanks Paul.
 I will do that , at least stop the annoying beep  .
Just hoping the control unit in the boot is fine
I did this when the wife's IQ had one faulty sensor and it was still perfectly usable..
Hi all.
Today the parking sensors arrived from China so I fitted two of them without improvement , still the buggers keep beeping randomly.
I noticed that the middle sensors currently fitted on the car are larger that the ones on the corners and have a different part number Denso 188200-3600
A quick search reveals that my two middle Denso sensors are actually called Corner sensors by Toyota.
Could it be that someone by mistake fittled the corner sensors in the middle and the  central ones in the corners of the bumper?
Would that affect the way the system works?
That's odd the early kit has only the 2 corner sensors, if you have 4 sensors it's the later kit these use the newer type sensors PZ464-00420 all 4 are the same sensor, unless it has an avensis verso or corolla verso kit on it
https://www.toyota-tech.eu/aimuploads/{20B27F42-6740-4912-B2CF-7BA61D9F958E}/TPA 400 AIM 000 097-0 PZ464-D0420-00.pdf
I have two big sensors ( supposedly corner sensors ) in the middle and 2 smaller sensor on the bumper corners.
i would find the control box and see what part number is on it
