Avensis T25 valve cover
T25nr
Hi all.
I’m having some oil leakage/sweating from my Avensis 2.0 D-4D. My first guess was the head cover gasket, and I figured this would be a pretty straight forward job. However, it appears that the turbo inlet pipe is welded (?) to the head cover? Has anyone done this job on this particular car?
I’ve made a circle around the turbo pipe on the picture. As you can see there is a bolt, but when removing it, there’s no way to move the bracket away..
