ekstra led bar high beam signal?
mikki1211
hello, i*m gonna mount a LED bar on my 2016 auris to get much bether high beam, but where and how can i get "signal" to my led bar relay?
Mikki.
Your fuse to tap in the fuse box that lies in the engine room is 35 or 36 (left or right high beam). I think it is a micro fuse tap that works here but not 100 percent sure since the fuses are so many different types nowadays. If you were from Sweden then I would have pointed out the correct discussion thread on this topic from Sweden. I have mounted a led bar on my auris 1.2T from 2015, it works but I get interference on the display sometimes with false tyre pressure alarm.
