High-mileage use case for `22/`23 Prius
pnibsc
I will have access to a `22 or `23 Prius for 6 weeks. It will be driven plenty (1,000-1,500 mi/wk) in hot, dry (>100 F, < 25% humidity often) conditions, and substantially all of these miles will be on the highway. Daily miles for the week are 400 mi/d x 1 and 300 mi/d x 2-3. What can I expect with preference toward performance and comfort? How do I configure and drive? Thanks!
Think the OP is in the Americas, so if quoting fuel consumption use US gallons rather than our Imperial gallons.
The Prius is basically driven as an automatic. You simply depress the brake pedal select D for drive; R for reverse; P for parking to disengage the drive, (accessed by depressing the P button) & B ( without depressing the brake) for when you are going down a steep hill - equivalent to selecting a lower gear. N on the shift is neutral & is not normally selected unless you want to disengage the drive from the front wheels, needed only in situations such as an automatic car wash. The handbrake is a foot operated pedal at the side of the brake pedal.
There are 3 driving modes selected using the appropriate buttons. Eco, for the best fuel economy driving; Normal, for normal traditional car driving or PWR (Power), for highest power driving, which is useful for overtaking or climbing up a steep hill.
Regarding comfort, I have driven several hundred miles with obvious breaks but have found the Prius quite comfortable for long journeys. I note you are driving in quite high temperature conditions. I cannot comment what the Prius is like under those conditions since in the UK we don’t experience such high temperature & dry conditions. The Prius has air conditioning but if used you have to remember that will radically affect your fuel consumption.
Hope this helps.
