Replacement gas struts for IQ boot
After cracking my head on the 3/4 open boot lid one day then watching my wife do the exact same thing the next day, I decided that enough was enough and the gas struts clearly needed replacing.
Nice easy job. Each end of the struts has a cup arrangement which fits over a nipple on either the door or door surround. There's a clip over the top of the cup which holds it all in place. You can free the clip by slipping a flat bladed screwdriver underneath and levering it. I found I could just pop the replacements on with a firm push without risking disturbing the clips.
The boot now opens fully under its own steam.
These are the ones I used at £22.49 the pair:
https://www.ebay.co.uk/itm/314522039653
  • Like 5
Many thanks James,I have the same problem with the sore head bit!ordered thanks.
  • Haha 1
Thanks OP for the post. I've been meaning to do this for ages, but was a bit unsure of the right part to buy and if they were decent or not. So followed your link, bought a pair, fitted them in 10 mins.
The little metal clips that hold them in were a bit fiddly, and I scratched them a bit when manipulating them with pliers, but it's not really seen and I'm very happy to have a boot working like new again!
... although it will take a bit of getting used to as the boot needs a couple of inches of manual lifting to start it opening and then it self pushes the rest of they way so suddenly that I've bumped my chin a couple of times!
There were plenty of cheaper struts available, but I couldn't find any info on the correct PSI (should have thought to ask on here tbh). I went for the ones in the link because they referenced the IQ and I hoped this would mean they'd have the correct pressure. They're not too far off anyway. Just keep your chin out of the way whilst they bed in 😋
Those are well priced - I replaced the gas boot struts in my old Mk2 with ones from SGS engineering and they cost that *each*!! :eek:
Yeah, I looked at those. I'd expect them to load the boot for me at that price 😦
  • Haha 1
