Anyone know the size of the Fan belt on the 5efhe???
J
if you got a A1 motor stores or bumper to bumper near you ask them for one. They will know which one to give you.
The make of the belt is Gates and it cross references with the one on the paseo 95+
Which "fan" belt? Seras with 5E-FHE have two. Neither operate the fan, because thats electric. One operates PAS and air con, the other water pump and alternator.
ill need the Pump & alternator
J
I would ask a motor factors for a 4 grooved belt measuring 825mm. This is what I use on a Sera. Paseo or Cynos may be slightly different - is there any markings on your belt?
ta mate - ill give them a try
ill take a look over lunch, im not sure ill get a chance though.
if not ill take it out this afternoon
J
Ok, got the alternator belt -
Andrew sorry to be a pain - have you got the details of the other belt & the Alternator itself?
J
