Hi all
I want to lower my 2006 verso.
But now I am also curious about which chassis is the same as the verso vvti 1.8 regard to springs
I saw on a site lowering shocks  of a gt86 The shock absorbers are very similar to the verso But I want to make sure of that before I buy, of course.
Thanks in advance
Springs and shocks are designed for that particular car/engine combination and to handle the weight
H&R 29191-1
Oké Then I know that.
You might have a website for the lowering springs
In terms of heritage, your second gen Corolla Verso (AR10, 2004-2009) is based on the second gen Avensis. The first gen Verso (2001-2004) was based on the E120 Corolla (ninth gen? I can never remember).
This does not mean Avensis suspension components will be a straight fit. But it might help you moving forward with you research.
The H&R springs that Flash22 listed are available from many places. Just confirm fitment.
Thnx for the reply, now I'm gonne search for the lowering spring and look what's best for me. Comfort, just a little bit lower that my wheels have a nicer fitment but still be able to drive normal with the fam and dogs in the car
Does anybody knows if the springs of the verso 04  will fit?
