I have the latest corolla cross hybrid with the digital dashboard. When I enter the car and my profile connects, there is in the right dial the Battery icon. I change it to tire pressure. When I turn off the car and turn on again, after my account connects I get again the Battery percentage in the right dial. How do I get it to stick to tire pressure? (or any other change for that matter?)
I think you have to save the changes in your profile before you switch off.
On 6/13/2023 at 11:57 AM, kgian said:
I have the latest corolla cross hybrid with the digital dashboard. When I enter the car and my profile connects, there is in the right dial the battery icon. I change it to tire pressure. When I turn off the car and turn on again, after my account connects I get again the battery percentage in the right dial. How do I get it to stick to tire pressure? (or any other change for that matter?)
I have the exact same issue, only the "tyre pressure dial" wont be saved. Its showing Battery everyday.
  • 5 months later...
How do you do this?
11 hours ago, Srdjan Simic said:
How do you do this?
Once you have linked a phone or the car key to your profile, you can save settings to that profile by clicking on "edit" in the top right of the page. Once you have all the settings to your liking, click the "edit" phrase again and it should be remembered by the car the next time it detects the keys/phone.
Wait, the one on multimedia? This one?
Thanks, will try that later...
Did this work for you??
Nope. 😞
Me neither, anyone got any ideas. Thanks
From the Owners Manual....
●It may take a few minutes to display the tire inflation pressure after the power switch is turned to ON.
I would surmise that because of this time lag between Power On and correct pressure to be displayed, this 'page' of the MID cannot be left in an 'On' state after the power has been turned off, and therefore defaults to another 'page'.
I hoped to find the tyre pressure readout available as soon as Power On as well, but to no avail.
Similarly, your rear fog lamps will not illuminate automatically on powering back up if they are left on when powering down.
They don't
My tyre pressures stay where I put them on the dashboard.
I'm signed in and have my phone as a linked devices so my profile loads up every time I drive the car.
Only had it two days though so there's plenty of time for things to go wrong
Unbelievable!!
Last night, out the blue, I'm sat watching TV (Vigil is very good!) and I get a notification from the MyToyota app saying:
The Corolla Hybrid MY23 2023 was successfully removed from your account.
wtf?
So this morning I linked the app again and went through the process of setting up the dashboard the way I like it.
And, wouldn't you know, lo and behold, my tyre pressure motor no longer remains in place on the dashboard.
Every time I leave the car and return it's gone!?! 😒
Surely this problem needs a fix?
