RAV4 HEV 2017 rear spoiler loose
Smani
Hi all,
Today during a car wash the rear spoiler came loose.  Tried to click back in however it does not go.  Hopefully did not break anything.  Has anyone had to remove or refit the spoiler? If so, is it only fixed by clips or is there any bolts/screws as well?
Thanks in advance
  • 5 weeks later...
Ok, I found and sorted out myself. Hope it helps someone. The edges of the spoiler are secured with a fixed bolt and a M5 nut each side (8mm socket needed).  The nut can come loose with vibration.  The access is through the boot door under a rubber cover.  Check photos attached.
  • Like 4
Good job Marcos. And posting the fix may help others in future 👍.
