hi can anyone tell me where to find a head gasket set for my poorly gti ae92
looked at fensports but nearly fell over at price
thanks in advance
The Fensport (TRD) ones are uprated for higher pressures I am led to believe, that's why they coast as much as they do.
You're probably best to just try your local parts dealer of Halfrauds if you don't want to spend that kind of money.
BEWARE OF CHEAP IMITATIONS. You don't want the gasket to go again, so it might be worth spending a bit more for quality!
might be worth going for a trd one,they are very well priced.considering an engine gasket set usually costs around £100 trade,just head and both manifolds,i think the trd one is well priced!and you know its never gonna go again.
thanks for help guys
reason i need it is due to siezed exhast valve and have to replace head with good one,do i need any other gaskets or just head one
regs
wayne
usually just head,exhaust and inlet,will also need cam cover gasket,amy also be worth having new valve stem oil seals fitted while head is off just to be safe.maybe have it ported and polished? :)
