2015 Auris - Am I missing undertray trim?
tapir
Hi Everyone,
Just a quick question, does anyone know if I am missing a plastic undertray part, it's on the drivers side under the rear bumper. There are fixing holes however no plastic? Perhaps omitted as they would be melted by the exhaust? The other-side has a plastic cover to prevent mud etc?
Any thoughts would be great!
It's a 1.6 petrol on a 2015 (non-turbo, pre-facelift)
Thank you all,
I don't think you miss anything. There is nothing on that side of Auris 2, only exhaust and galvanized bare body. Not painted either. There are some common surface rust there, you can just spray a cold zn-alu spray on those holes.
Thank you both,
If anyone in the future has the same question, there is a bit missing and apparently the part number is: T57627-02100
However from Toyota it is rather expensive at £79.33! So I think I will be trying to get it from a breaker instead...
Thanks will get the rust treated, better now that later!
  • 4 weeks later...
I use simple spray paint Zn-Al and black spray from LIDL.  For hard to reach, we can use fluidfilm fat spray. It is better than any thick rubberised coat that often trapped water and accelerate rust.  I think my car do not have that flap either. I think it is only possible if we also have rear mud guard installed too.
