Toyota celica 1994 ST202 Which gaskets ?
ashj22
Hi guys. I'm replacing the straight pipe i have on and putting the catalytic converter back on.  Does anybody know.
1. Am i supposed to use gaskets for both sides ?
2. Which gaskets do i use ?
I'm assuming on the front there is spring bolts and these wont compress the joint enough for it to be leak free using a flat gasket like this.
https://www.ebay.co.uk/itm/233264775214?
The front end is where you can see the past sealant.
What i'm thinking is a donut gasket something like this https://www.ebay.co.uk/itm/402173556901? on the front and the flat gasket on the back ?
