Yaris TS et39 wheels.
Raeman
Hi all I’ve got myself some wheels with an offset of 39 for my 2004 TS.
just wondering if these will fit or will I need spigot rings?
cheers guys.
cheers guys.
Alcar 7010 5.5Jx14 ET45 4/100 54.1 steel rim (Yaris 1999-2005)
Alcar KFZ 7010
https://www.oponeo.pl/felga-stalowa/alcar-kfz-7010/23366304
Alcar 5710 5Jx14 ET39 4/100 54.1 (Yaris 2006-2011)
Alcar KFZ 5710
https://www.oponeo.pl/felga-stalowa/alcar-kfz-5710#23366302
Alcar 5975 5Jx14 ET39 4/100 54.1 (Yaris 2011-2020)
Alcar KFZ 5975
https://www.oponeo.pl/felga-stalowa/alcar-kfz-5975#23319843
What make alloys ? OEM is a 54.1 mm centre bore as for ET it depends on the width of the rim and tire combination if you need spacers
Hello flash
wheels are speedline 6jx15 with 195/50/15 tyres.
Are they the speedline corse if so they will be 6.5J in a 15 et 35
spec and model should be in the casting on the back of the spoke
the SL rims are 65.1 mm or 56.6 mm CB, but i would have a quick measure
Hi flash their Speedline safari 6Jx15 H2
39 ET.
SL 957
thanks.
