Hi All,
I am looking to install cruise control on 1NRFE NSP120 MT i have clutch switch installed.
I am looking if some one guide me where is the ECM connector is located
Its called AF4 pin 12 and colour is beige it seems there are connectors before ECM PIN 60 A58 BLACK connectors but i am unable to locate this
any question pls let me know
thanks a lot.
https://ibb.co/LrztZVD
What are you trying to find ? The ecu is in the engine bay
first off, do you have audio controls and have you fitted the stalk ?
What wires do you have at the clockspring under the steering column cowl
2012 is early for CC and the 1.33 is very hit and miss if the ecu has the programming for it, PM me your vin
edit. Cruise was not an option until 12/2012 on the 1.3
so need to run beige from here to AF4 connector then to ECU if its not wired. what i noticed on some NSP120 is they installed from here to connector and it worked.
Your car was built 03/2011 the ecu does not support cruise control (you can not program the ecu for it), you do not have the wiring
you are wasting your time
Thanks Bob much appreciated.
