Previa D4D replacement - can I use Avensis, Auris etc. ?
I've got a 2.0 D4D Previa needing a replacement engine and turbo.
How much is transferable between other model D4Ds? There are few Previa engines about but loads of Avensis, Auris etc.
Obviously I have manifolds, mounts etc. To transfer over. Turbo is suspect and bottom end has had oil starvation.
It's an 02 Previa.
Thanks in advance!
Moved to the Estima forum.
I believe I'm looking for a 1CD FTV for that year of Previa.
So if I were to get a full 1CD FTV Engine from a Corolla would that be a straight swap or workable with mounts, manifolds, brackets etc. Swapped?
Is the year critical?
