Yaris mk3 washer arm
JCT-DK
Hi
I realize that i don´t have the kind of washer arm with the option of setting the interval in mulitple time delays.
I have the standard option of setting normal-fast-interval (one step).
Anyone knows if i can replace with a later washer arm (i guess from the mk3 2017-) and programme the ECU?
Thanks!
KR JCT-DK
You only get adjustable wipers if you have auto wipers and auto lights, so no you can't just add a stalk
With adjustable wipers you mean auto wipers (rain sensor)?
Strange on my old Micra with no auto function I still was able to set the the interval of the wiper speed.
It depends on the spec of the car, a base 1.0 has next to nothing
84652-0d180 - without auto wipers
84652-0d190 replaced by 84652-52290 - with auto wipers
the stalks are the same 2014-2020
I just looked it using my cars VIN and unfortunately it is the scrren wiper without auto function.
So installing the wiper arm with auto function and coding the ECU want do it even if the cars is´nt prepared for it?
It's not programmed into the ECU, you do not have the correct wiring or sensors
Okay thanks.
