Yaris 1.33L (1NR-FE) Valve cover gasket replacement
redhyper
I am going to be replacing the valve cover gasket as it has been leaking oil into the spark plugs. The picture of it doesn't appear to have any spark plug gaskets like they do on other yaris valve cover gaskets. Does anyone know if I have to buy these separately or how do I go about changing them? I watched videos of people replacing these for yaris' but they are not the same engine and have the spark plug gaskets already attached.
Here is a picture of the gasket:
750x750_29440_93e05faeda45e105ed902a7f24
IIRC the plug well seals come as part of the cam cover, don't buy a cheap valve cover gasket - oem or Victor Reinz
I have bought one by 'febi bilstein.' I looked on the victor reinz catalouge and the picture is similar to the one I posted: 67f50a7a309814606238b186cb5ca1003623ad19
Still no sign of the orings and none of these parts companies have them in their catalouges. so I'm quite confused.
https://web.tecalliance.net/reinz/en/parts/cars/assigned?assemblyGroupId=100223&targetId=9257&typeNumber=9257#@brc/brands:Car;targetType:cars/assem:TOYOTA%20YARIS%20(_P9_)%201.33%20VVT-i%20(NSP90_);targetType:cars;targetId:9257;typeNumber:9257/lnkparts:Gaskets;targetType:cars;assemblyGroupId:100223;targetId:9257;typeNumber:9257
When removing/replacing rocker cover there are several parts over and above the rocker cover gasket that are considered non reusable parts see:
Anything marked with a black dot are non reusable, you will also require sealant to apply over the joint between timing cover and cylinder head see:
So valve cover gasket and sealant is all I need?
The sealant is for the outer gasket see the above diagrams, as i previously said the plug well seals are part of the cover
I'm still trying to make sense of this..
It says I also need 2 Cam Bearing Cap Gaskets as well as a one for a bolt, which I can't find any of these online.
