2010 T27 Avensis - no roads on SatNav 😱
ToNo10
Hi, got into the car this morning and noticed no actual road/street outlines on SatNav, just the usual coloured background. Has anybody got any ideas - I have pushed all the one screen buttons to no avail.
thank you 👍
thank you 👍
his usually happens when the screen image is zoomed too far out
Many thanks 😤  I will give it a try 👍
No, it didn’t work. I pressed every + and - on Sat nav map position of car on map showed but streets didn’t show up.
What Software/Map version is installed?
Press setup , scroll down to Software information
I will have a look today, the strange thing is is has worked ok for years. I have not touched it and then one morning this starts 🤬
This is the SD card info. It has worked for years without a problem.
Tony, SD cards do not last for ever.  12 years of use is a lot.   From the web:
'SD cards are designed for data storage and should last for 10 years or more. Frequent users should replace their SD cards every few years. Professional photographers should have a substantial collection of high-quality backup SD cards on hand.'
Too late for you so either buy a new card or use a phone app.
One cheaper solution is look on eBay or actually post as a want.
There 20-21 version on eBay for £30.  If the seller will accept a return, perfect.  If it does not work,  you can always sell it on.
Many thanks, will try that. I do use WAZE which is free and much better than Toyota SatNav, it gives speed traps info too.  But sometimes it’s good to have backup SatNav.
But surely if the sd card was corrupted it wouldn’t affect just one perspective view of the map would it?
They often corrupt a little at a time. So depending on how the satnav app works (and handles bad data) it could well be the cause of your issue.
Further to this problem: Received a 21/22 ‘new’ SDcard this morning, no change 🤬
can anybody tell me which fuse to remove in order to reset T27 SatNav?
thank you 👍
