Bad integration relay? (T22 2001)
Ave I FIN
About a month ago my central locking died completely. I gave the integration relay a reset by removing and inserting the dome fuse.
Reset helped but until recently the boot lock has started to fail. It works a day or two and then dies. Removing/inserting the dome fuse
helps for a while. Alternatively I can turn the lock (move the lock motor) which helps too (not opening the boot).
I have tested the lock motor separately and it is fine. Also when the issue is active the is no voltage (only two wires) coming to the motor.
My question is how would moving the lock motor make the integration relay work for a while? Could it be the wiring harness? How to measure it?
