Brake Pedal Click
1949terry
2016 RAV4 AWD 31k miles, when braking at very low speed , there is an audible CLICK when depressing brake pedal. Main Dealer struggling to identify. Any ideas anyone. Thank you in anticipation
did the they admitted that there is an abnormal click and couldn’t find the reason? Usually all cars has clicks when press the brake pedal as the brake light switch been pressed too. Some are more audible than others. If it’s too loud, perhaps you can undo and remove the switch from the pedal and try pressing without to see if the click is still present, if yes next is the master cylinder to check if no means the problem is within the brake light switch. If everything works fine then better leave it and you will get use to it.
Regards
