Creaking sound Avensis T22 pre-facelift
34082304823048
Hello.
I have a creaking sound from the right front wheel on my Avensis T22.
It can be heard when "touching" the accelerator at low speeds, or when rocking the car back and forth when it's parked in gear, never when coasting.
Any idea as to what this can be?
It sounds like something is not adequately lubricated.
It's the sound in the provided video, from the five second mark.
Cheers
You will have to lift each wheel in the air to check if it does the same noise. It sounds like brake pads are slightly touching  the discs, typical noise or perhaps the dust covers. If it doesn’t do it with wheels off the ground could be from suspension too.
