Rattling sound behind the glovebox
JonnaS
Hi! I recently changed the radio in my T25 and everything went well and works fine. The only problem is, that when I change the temperature, put ac on, press where i want the airflow etc, I can hear a kind of rattling noise behind the glovebox. It is still working fine, but the noise is making me nervous. I plugged in in properly when mounting it back.
Also there hasn't been that sound before, so i don't think there's any leaves or anything like that.
Perhaps you should remove the glove box and listen where exactly does that noise coming from? Maybe you have already done that...
It's an Avensis problem. I took a video of mine last year.
You can see the pin jumped out of the cut-out, you would need to guide it back in again. Unfortunately this is the easy bit, the difficult bit is to open the black box the electrical motor is attached to and spread the lubrication evenly. It's tricky and I need to admit I couldn't open mine so I just left it for now.
I saw an instruction how to do it but the link doesn't work anymore.
