I supposed it 🙂 thanks!
@flash22 another question: will the warranty be invalidated? In Italy we have 10 years warranty on EV battery
We are luckier here in the UK (for a change) 😁😎
15 Year Toyota Hybrid Battery Cover
In addition to the manufacturer warranty, your Toyota Hybrid Battery can benefit from up to 15 years of warranty in total. With every service at a Toyota dealer, the warranty is extended for a further 12 months, up to the 15th year of registration.
https://www.toyota.co.uk
In addition to the manufacturer warranty, your Toyota Hybrid battery can benefit from up to 15 years of warranty in total. With every service at a Toyota dealer, the warranty is extended for a further 12 months, up to the 15th year of registration.
Lucky!!!
we have 15 years warranty for mechanical and hybrid components and 10 years only for the Battery (exclusively with service done every 1year or 15.000km)
3 years left for me and the EV Battery is in good condition (hybrid assistant)
Techstream 18 is the latest.
on saturday the mini VCI will be delivered, stay tuned 😆
On 8/26/2024 at 5:31 PM, flash22 said:
laptop and mini VCI with Techstream you can then do function tests and reset things, some systems and ecus are only accessible with Techstream
hi flash, what screenshot do you need or what test can I do?
connect to the car and run a health check (Left hand grey menu)
Here
Update @flash22
a lot of these codes are from unplugging things and are history codes - just clear them
go into the entry and start, on the left select active tests
Here we are
see if the power/engine SW light has any effect - it will connect and show on/off buttons in the bottom right of the screen
It seems the same in on/off mode
The power button doesn't change anything with on/off
that shows you don't have control. try it with the immobiliser light
is the car locking and unlocking as it should? lock the car and try every door
The car locks perfectly as it should, every door (also trunk) and same with unlocking
No changes with immobiliser as shown above
does the light on the dash turn on and off tho
The dash lights turn on like there are no problems
also the interior lights
That is how it works
remove the LEDs from the interior light
Nothing has changed, with OEM interior lights and with any bulb installed
connect to the car - entry and start - click on utility (left menu) - customise - engine start indicator turn it off
