1991 Camry 2.2 GL compatibility with US 1992 2.2 GL?
tercel_fan
I have a 1991 Toyota Camry 2.2 GL. It was purchased in Europe.
Rockauto.com only sells parts for the 1992 Camry GL 2.2. They are also marked USA/Canada.
Does anyone know if all the 1992 parts are compatible with the 1991?
I posted this question on another forum, received the following reply, but they deferred to the expertise on this forum to confirm:
The Camry GL was stated to be totally redesigned in 1991. Then another major model change was in 1996. This year range corresponds to what was called a wide body chassis labeled XV-10. If this is true then 92 parts should fit a 91 with a few exceptions. Toyota makes major model changes every few years and in between does minor cosmetic changes.
