Removing and cleaning dpf Yaris 2010
Kenito
Hello, any experience getting the dpf off a yaris 2010 and cleaning it? I see it's two parts close, I guess the first part is the catalytic converter? And then it's the dpf ? Do I need to remove it from under, or over ?
I think you'll find the only efective way of cleaning DPFs is for commercial vehicles. I suspect your most economic option is replacing the DPF.
I disagree with that, I agree when it comes to solutions that doesn't remove the dpf is very hit and miss, but there is chemicals and also companies that has special cleaning methods that does a very good job, that guarantees a 99% clean filter, for 250€, that's a much better price than 800€ new filter.
https://m.youtube.com/watch?v=Zw-EAc_Lpv8&feature=share
