2023 Toyota Yaris hybrid design LED headlights
Andy-uk
Have just purchased a 2023 Toyota Yaris design hybrid with Led headlamps and struggling to find out if beam deflectors are required when traveling in Europe,  been told that as led headlamps produce a flat beam on dip none are required but also been told that all UK models dip to the left, has anyone with later model yaris with led headlamps travelled in Europe lately and did you require eurolite stickers.
Sometimes on the rear of the headlights there's a lever to deflect to right side?
You have a Mk4 Yaris hybrid, and aside from the poverty-spec one, which uses halogens, all the higher trims have projector-type LEDs which have a flat cut-off when dipped.
The short answer is you don't need beam deflectors!!
You can see for yourself - When it's dark, point the car at a wall and turn the dipped beams on: You'll see the light has a sharp cutoff above a certain height, and is dead flat from left to right.
I was in the glorious, prosperous EU recently, didn't apply any headlight stickers, no-one flashed me. The beam pattern is very flat, pretty sure no beam deflectors/stickers needed
Hold on, didn't you post this somewhere else already?? :eek:
Yes, the Q has been asked previously and I gave the same response
Hi, Cyker i asked in the wrong forum by mistake and couldn't figure out how to remove it from there ...
Ahh okay, good to know I'm not going mad :eek:
I'm sure frosty will be along shortly - He lives for the opportunity to merge threads :laugh:
  • Haha 2
Similar topics merged.
We love you really frosty :laugh:
I fel a Christmas song coming on.
  • Haha 1
