Does Toyota or anyone else sell complete replacement front struts ?
For my late 2008 Aygo Petrol
Hi there iv not been here long but I see the site has a deal I think with ebay  maybe checking in there .
Why are you changing yours  does the car squeak when you go over a speed bump . Cheers
Not sure if you can get quick struts in the UK/EU i thought it was only a US thing
most garages will swap shocks and springs over for a small fee if removed from the car
autodoc are one of the biggest online suppliers of car parts in Germany, and they don't list any front shock absorbers that come with the springs already fitted for the Aygo 2005-2014.
You might be able to find a youtube video on how to fit springs to front macpherson shock absorbers, and the tools that you will need such as a spring compressor. However, the information you need is often model specific, so try to find one about an Aygo and preferably the 2005-2014 model, or one of the Peugeot/Citroen clones.
The Draper 14173 coil spring compressors are one of my favourites for doing MacPherson struts.
Front shock absorbers (for Aygo 2005-2014) (Bilstein, Sachs, KYB, Monroe, etc.)
https://www.autodoc.co.uk/car-parts/shock-absorber-10221/toyota/aygo/aygo-wnb1-kgb1/18813-1-0-kgb10?fromSearch=1&supplier[0]=85&supplier[1]=32&supplier[2]=16&criteria[100][4]=VL&supplier[3]=37&criteria[100][5]=VR
Draper 1x 250mm Pair of Coil Spring Compressors Professional Tool 14173 - Picture 1 of 5
https://www.ebay.co.uk/itm/391954737030
Yes, checked eBay, only found some in Germany
Mine are ok, but sagging a little on my side
Not noticed a squeak
Thanks. I am pretty sure, IIRC, a few years ago when I had my Corolla, Toyota dealers could supply complete replacement struts, hoping it was same for the Aygo. I have fitted / replaced struts before, a pain. I was trying to avoid having to get all the parts individually
Thanks, have checked eBay and I already have road spring compressors
If you are happy to buy all parts from the dealer you can have a chat with them and ask to make them in whole strut assembly for you, they may charge a bit extra but then will be super easy for you to replace them afterwards. Otherwise you have to buy separately and compress the springs buy yourself.
KYB or Bilstien shocks/springs better than oem an 2/3 of the cost of oem , but i would get the tops from the dealer
KYB shocks look to be in the £60-65 each oem are likely to be in the £120-150 range
KYB shocks 33808, 33807 - Springs RH3004, Top Mount SM1930
Around £110-120 a side
Toyota lists the shocks in parts, not a whole
Edit. i would also do the drop links and anti roll bar bushes while you're at it
Ok I found a vid and the bottom one don't come off so it pulls the spring down  mmm cool .reason I asked is when I go over a speed bump the left side squeaks  why I asked if yours does . Cheers
a squeak is usually bushes, roll bar bushes and drop links are big cause, lower arm bushes can also degrade with time/mileage
