Auris Hybrid (2015) Gen 2 AC Condenser spec
AurisA
Hi All
does some one have a Spec/ Data sheet on which AC Condenser is required for Auris Hybrid (2015) Gen2 please
dont want to procure the wrong part. My dealership is doesnt have in stock so need to by online.
Ta
You always can buy DENSO condenser in Amazon or Autodoc.  I used them and they are close enough to the Toyota Genuine OEM parts.  Some OEM parts and aftermarket are identical such as AC parts, water pumps, Starter, and Alternator.  However, the shocks/struts, brake pads and disc are often not the same even they are all made by the same supplier KYB, Advics, etc.
I suggest you go to Hybrid and EV speciealist for AC system before they contaminate it with PAG oil and cause high voltage leaking.  Or you can do it by your self. We only need:
1. AC gauges with low, high, vacuum, and filling lines for about £40
2. Vacuum pump
3. Pure 134A and ND11 oil
4. Original Toyota rubber gaskets on all connections that we unplug.
It is relatively relaxing works since it is right outside the car, not the evaporator inside the dashboard with tons of wire and electronics. http://www.japan-parts.eu/toyota/eu/2014/auris-hybrid-ukp/zwe186l-dwxgbw/1_166520_038_519W/electrical/8718_heating-air-conditioning-cooler-piping
We should replace the dryer too when replacing condenser. it is just right at the same place. I am not sure if the Condenser unit already come with the dryer.  We can vacuum the system for few hours probably 1-4 hours to make sure all the air are vacuumed and any water contamination will be boiled and get out from the systems.
Nissens are quality brand if no Denso is available. You can look with oem numbers online.
