Hello,
I've recently purchased a 2015 Toyota VVT-i x-play and I would like to purchase some new wheel trims as the current ones have some marks. I currently have 15" Wheel Trim 6 Twisted Spoke fitted but have noticed that there is also 15" Wheel Trim Multi Spoke available and would fit the car. Is there any reason for the different versions of wheel trims and which ones would be best?
The 2014-2018 Aygo wheel trims are as above.
The 2018 facelift had the wheel trims above.
Some owners found the wheel trims on the facelift made the tyre pressures difficult to check unless the trims were physically removed.
