Prius 2019 replacement wipers
Fozla
Hi
Hope all is well with everyone here. Apologies if this has already been answered. I did check the forum but could not find an answer.
I have a 2019 Toyota Prius and need the front and rear wipers changed. Any recommendations for what brand I should go for? I look at the Bosch Aerotwin which have the multi-purpose fit meant types. However, I’m just concerned whether they will fit the car or not or do I need to go to Toyota directly for replacements?
Thanks in advance
I've used Bosch AR26U and AR15U which fit fine.
I've also used these silicone refills https://www.amazon.co.uk/gp/aw/d/B081PQ2DZL
They, or similar, let you keep the original Toyota frames, which are a bit neater than the Bosch ones.
Thank you very much for your kind replies. They have been most helpful
