Smart Connect Audio Fault (cleared)
Roy124
Today the audio selector on the steering wheel would not work.  It would neither change between FM, DAB etc nor would the station selector change.  All that happened were beeps.
On the smart screen you could select FM, DAB etc but there was no audio from DAB.  FM audio and volume were fine.
After switching off and later switching on, everything reverted to normal.
At least you didn’t have to press Ctl, Alt and Return or get the blue screen of death. 😂
Hi Roy
Just had the same thing happen to me except DAB was no longer on the smart screen                                   returned to normal after switching of the on again
