EPS light on when hot and parked under the sun
Biomecanoid
Hello,
I have a used 2006 Daihatsu Sirion 1000cc and the Electric Power Steering light comes on accompanied by a series of clicking noises when its very hot outside
When the EPS light comes on in order to make it functional again i have to turn the steering wheel while turning the car on, then it works reliably.
Also tested my Battery with the Topdon ArtiBattery101 tester and its 98% charged 100% healthy and the Battery its self is 400CCA which is more than then car needs.
I downloaded the service manual for the car and just bridged  the 2 terminals as shown below:
and got error codes 52 -55 - 57
https://youtu.be/oc2tbOHaaZQ
Any ideas of what can I do, all the mechanics want to change the motor but my guess is that the computer module is the one overheating and failing the initial check when you try to start the car.
Electric power steering never went out while driving only when starting the car after being parked under the sun
Thank you
