Air con update.
Stivino
I just thought I would poat an update on the air con repair that I did two and a half years ago.
I had a burst pipe.
20210312_202140.thumb.jpg.d2a1dce7854327ef768aca8349a674fc.jpg20210220_120809.thumb.jpg.5d07952ba1bf3d11df372762677ef5c2.jpgI cut the piece out where the leak was and used an 8mm compression fitting to reconnect the pipe.
Yesterday, I weighed the gas bottle to see how much gas was left in it and, I put the last 20g of gas that was left into the system.
I took the car for a run and measured the temperature of the air with the air con on.
As you can see, it was 5.2°C.
This is the gas I used.
20230726_122307.thumb.jpg.551c0d4ddb86bec0b5505071430aa283.jpg20230726_122343.thumb.jpg.4b0156da5ac3c2cc7c372e83eb2f83da.jpg
  • Like 3
