Has anyone else noticed how the range calculater has a drop down for the Battery and charger type. ?
I do wonder if Toyota plan to change these, as I'm not sure why you would create a webpage with drop down selectors if you only have one Battery pack and charger type?
In practice, they don't have a drop down - just a graphic that looks a bit like one ...
They already have two charger types - early cars were shipped with a 7kw (nominal) charger which is simply not supported by the calculator.
But at least it does give a reasonable idea as to how rapid charging rates are affected by the ambient temperature.
