I cannot find any info in the instruction book for the AC control.
The LH knob says Dual and the  RH says Auto, if I turn them down the display says LO
Can someone please explain,  is doesn't seem very cols
Dan, those are the left and right (or both) temperature controllers.  The conditioning function buttons are the row below the temperature display.
The extreme left is AC.  Then you have the choice between fresh air intake or recirculation.  Next is the vent direction options.  Next and central fan speeds down and up.  Then the defrost screen options.  The last is Off.
If you want to move the car without the ICE kicking in, power up and immediately press Off.
I will leave you to discover how to switch ot back on 🙂
I am familiar with the controls from my old Toyota , it's the 2 control knobs that I am quering,  why does one say DUAL and the other say AUTO ?
and what does it mean when it displays say LOW
Dan my understanding is this,
Lo is the lowest tempriture you can set turn it up slightly and it will read degrees.
Right hand knob push in the center it goes green led and now its in automatic mode with eco fast settings control button below the word in on the display.
Left control is independant or dual cabin control tempriture settings on/off by pressing inside the knob center.
Auto - you choose the temp and then the car will monitor and maintain that temp within the car. This may mean cooling or heating the car throughout a journey.
dual - this is where you control the temp from drivers side or if activated the driver and passenger can select different temperatures.
If you have a play with it it becomes clear.
Left rotary button allows the front passenger to adjust their own temperature. Right button adjusts the driver's side unless 'Dual' is lit in which case it controls both sides.
Pressing the right button in the centre activates 'Dual' mode and possibly deactivates it although that happens anyway if the passenger side button is rotated.
In both case you choose a temperature and the systems does what it needs to maintain that temperature.
