Nonstop Warning Sound Behind Dash
ellenmagx
I have -08 D4D Avensis, and it started to make beep sound, as a non stop and it has nothing to do with those alarm sounds for seatbelt/lights etc, and it's not even similar sound. This is a plain nonstop- BEEEEEEEP
Everything works, except TRC-off button doesn't react or something doesn't react on TRC-off button. And i don't have PDC on my car.
Beeping starts when i turn key to ACC and stops when i turn the ACC off. And it also continues while driving, as nonstop.
Now I've located that the beep goes off if I take fuse "AM1" out, but it also turns off the instrument panel on the dash. Anyone have any idea what might be causing the problem?
